KNUT
Posts: 286 Joined: 12 Dec 2005, 09:57
Post
by KNUT » 14 Dec 2005, 12:01
Hello!
The "Select the target directory" box (via Copy/Move -> Browse) ist _not_ resizable.
I would like to see a "resize"-Icon in the bottom right corner...
TIA!
Moderator: poll closed and deleted.
Kind regards, KNUT
Posts: 5231 Joined: 08 Dec 2005, 06:34
Post
by Jan Rysavy » 14 Dec 2005, 13:42
Implemented. This option will only work with Common Controls 5.00 and later.
Thank you for this idea!
KNUT
Post
by KNUT » 14 Dec 2005, 13:58
Jan Rysavy wrote: Implemented.
Fine
In witch Version ?
Jan Rysavy wrote: This option will only work with Common Controls 5.00 and later.
That means...?
Jan Rysavy wrote: Thank you for this idea!
You're welcome
Kind regards, KNUT
Post
by Jan Rysavy » 14 Dec 2005, 14:23
This feature will be available in the next Servant Salamander release (implemented just now).
