Excel hangs when customizing quick access toolbar
When trying to customize the quick access toolbar by going into the customize menu and selcting "more commands"-> "select command" -> "all commands" excel hangs with a VBA failure message. All other options than "all commands" work fine. I suspect that is something to do with Salamander because the command seem to work properly on computers where Salamander is not installed.
Re: Excel hangs when customizing quick access toolbar
Do you use Altap Salamander 2.54? Could you reproduce this problem when Salamander is not running?
I withraw my remark and it should be ereased from the forum. I'm also using ASAP Utilities in Excel. This is the plug-in that causes the problem. I'm sorry to have confused ALTAP with ASAP. I think Salamander is an excelent software. I use it daily since several years. Sorry for the confusion.
No problem. Thank you for info
