Hello forum members,
I recently joined the forum.altap.cz community and I'm facing an issue with the file manager on mobile. I have two panels, one on the left and one on the right. The problem is that when I try to copy a file from the left panel to the right panel, it ends up moving the file instead of copying it.
I've checked the settings, but I couldn't find a straightforward solution. Can anyone guide me on how to fix this? I'd like the selected files to be copied to the right panel instead of being moved.
Any help or advice would be greatly appreciated! Thank you in advance.
Need Help with File Copy Instead of Move in Panels
Re: Need Help with File Copy Instead of Move in Panels
Thankyou!SelfMan wrote: 02 Feb 2024, 13:53 F5 - copy
F6- move
for more shortcuts visit:
https://www.altap.cz/salamander/help/sa ... _keyboard/
I was actually unware of this. Thanks for telling f5 and f6 keys.SelfMan wrote: 02 Feb 2024, 13:53 F5 - copy
F6- move
