Lothar
Posts: 1 Joined: 08 Jan 2024, 21:12
Post
by Lothar » 08 Jan 2024, 21:23
Hello.
I have trouble opening some ZIP-files from time to time:
This file was compressed using a method that is not supported by this version of the ZIP plugin. "
My system ---> Altap Salamander 4.0 (x64) / Plugin: 7-Zip v1.31
Is there any way to upate the plugin?
cu,
Lothar
Posts: 5231 Joined: 08 Dec 2005, 06:34
Post
by Jan Rysavy » 10 Jan 2024, 10:54
Can you show us such ZIP archive?
Posts: 1181 Joined: 05 Apr 2006, 20:51
Post
by SelfMan » 10 Jan 2024, 23:42
Can you rename the zip to abc.zip and try to open it? Do you still have a problem opening it?
Posts: 700 Joined: 14 Dec 2006, 06:22
Post
by therube » 11 Jan 2024, 17:29
A zip using PPMd compression algorithm.
(7-Zip will open said file.)
Post
by SelfMan » 11 Jan 2024, 19:01
Ok, I am confirming the problem.
