Drag'n Drop to Hot Paths
nmccamy
Post by nmccamy »
How do I drag'n drop a folder to the Hot Paths toolbar? If this cannot be done, I will put in a feature request.
Re: Drag'n Drop to Hot Paths
since hotpaths are assigned to slots, and each slot has it's hotkey to use that hotpath please use the hotkey to assign the current path to the desired slot. With drag'n'drop to the toolbar there is no easy way to assign the path to a specific slot.
Use SHIFT+CTRL+<Digit> to assign, CTRL+<Digit> to apply a hotpath.
