Cell Phone
selkov
Cell Phone
Post by selkov »
New user - Likening this a lot. Except I cannot find my cell phone when I connect it to the pc.
Help.
Re: Cell Phone
From the manual:
Getting Started with Windows Mobile Plugin
With Windows Mobile plugin you can access Pocket PC, Pocket PC Phone Edition, Smartphone, and Windows CE devices. You can explore your mobile device's directories, view files, copy, move, delete, rename files and directories, or change their attributes. Microsoft's ActiveSync software must be installed on the desktop computer to connect plugin with your mobile device.
So generally this is not for all mobile phones. Your device must support MTP protocol.
Check also viewtopic.php?f=4&t=44406&p=70601
