Can I transfer files between my old pc and new one, on the same Wifi or ethernet, using Salamander?
MamaBear
Post by MamaBear »
I'm a bit of a network novice but an old registered Salamander fan.
I just got a newer PC and need to transfer folders from the old to the new one.
This would be ideal if I could use Salamander!
Re: Can I transfer files between my old pc and new one, on the same Wifi or ethernet, using Salamander?
Yes, it is possible. You need to share a folder on the remote/new system.
see https://support.microsoft.com/en-us/win ... f9994725bf
I recommend doing it via ethernet cable.
Is it a laptop or a PC?
