Unpacker: .cbr/.cbz issue
dagmarsawayn
Post by dagmarsawayn »
I was exited by DN/NDN back in ASCII time, but I must say that this app is all I need and don't go anywhere without it (you know when you get used to some software and when it misses from the system it's just too bad feel :D) so thanks for making it
It has everything I can imagine and it's dirty fast in it tasks
Old windows controls doesn't bother me
OK, I've said it ;)
The reason for joining in here is a minor bug: salamander recognizes .cbr/.cbz files, but when unpacking .cbz (which are ZIP packed) it assumes it's RAR archive
Take care
Re: Unpacker: .cbr/.cbz issue
I believe .cbr / .cbz are not associated to any archiver by default.
Please check and alter your configuration in
Configuration | Archivers | Archives Associations in Panels
You can just edit the list of extensions, or create an entry for cbr;cbz and configure it use ZIP (Plugin) as associated archiver.
