Replacing WinSCP with sftp plugin on AS x64 4.0
I'll add to the latest tips series a dearly missed WinSCP replacement. Not kidding and it really works!
As you probably know WinSCP plugin is not available for the AS x64. We can save the day again with the Manison's proxy plugin. It works as a charm and enables you to connect to any sftp server you need. Currently the only feature that does not work, that I know of, is the check box Protect With Password Manager (TC>=7.5).
Prerequisites: You need to follow the instructions of TC proxy plugin to register the plugin.
How does the sftp plugin work? Actually quite great!
Here is how it looks like connected via sftp and showing a file:
This is how the sftp plugin connection dialog looks like:
The commands for the plugin:
Plugin help:
F7: create new connection
F8/Del: Delete connection
Enter Connect
Alt+Enter Change options
You can store the session which will be then at the list:
Re: Replacing WinSCP with sftp plugin on AS x64 4.0
Nice job putting it all together. :D
SelfMan wrote: 18 Feb 2021, 23:40 Nice job putting it all together. :D
Thank you ;). Main credit goes to Manison for creating such great proxy plugin!
Thank you Manison!
I think this will help many that want to use WinSCP also with the OpenSSL 1.1.1g or greater, which makes WinSCP unusable. Like already noticed at the post WinSCP plugin - "Couldn't agree a key exchange algorithm"
crystalidea
Post by crystalidea »
Unfortunately, it doesn't support owner/group/rights columns and not way to edit file/folder attributes as well.
crystalidea wrote: 26 Feb 2021, 12:41 Unfortunately, it doesn't support owner/group/rights columns and not way to edit file/folder attributes as well.
As often in life, nothing is perfect. It all depends on your workflow and configuration. Here are some options/workarounds you have:
ddit file/folder
- You can do that by connecting as desired user/rights and move the files.
- Other option would be having a cron script that would check the rights. In case of deviation it would fix them to desired ones.
Yes, this feature is missing. The only option that comes in mind would be a sftp script that would produce a temp text file for each directory you visit. There you could view the attributes.
As for the software itself you could:
  • Edit the plugin and add the changes you need.
    Since the source code is available sftp plugin source code you can edit it and add the changes you need.
  • Pay somebody to edit the plugin's source code or create a new one completely new plugin
  • Ask the creator of the plugin (Ghisler himself) to add those
    I don't know if this would be possible for TC (my guess editing the properties should not be a problem, displaying columns would depend on TCs internals).
antp
Post by antp »
Thanks for providing a solution for the WinSCP issue :)
However I could not get it working...
As error message it just says "Error: failed to connect to the given server!"
is there a way to get more details about the error?
Such error is nearly impossible to debug on the client's side. You need to check the server's log(s). Also don't forget there is a new version, currently 2.80.
New in 2.80: Prefer curve ED25519 host key if available, may lead to warning that the fingerprint of the server has changed
antp wrote: 12 Oct 2021, 09:34 Hi,
antp
Post by antp »
As I did not find anything in the log (like if it did not reach the server) I checked again the setting and the IP displayed, then I noticed it tried to connect to port 22... which is the default one, not the one of my server :roll: After putting the correct port I get the next error, more explicit (about the key), I should be able to get it working, I'll investigate that later. [ edit: it works fine now! ]
Thanks for the idea of checking logs :D
antp - it would be nice if you'd share the solution you applied with the community.
antp
Post by antp »
For the port: I just added ":xxx" after the server address, where xxx is the SSH port number of my server
For the key error that I had, I just unchecked the option to use Putty (as my error mentioned in the message above was related to that) and it seems that it is ok for it to work without specifying key files actually.
Ok, thanks. This might be useful for others in the future.
antp wrote: 01 Nov 2021, 09:52 As I did not find anything in the log (like if it did not reach the server) I checked again the setting and the IP displayed, then I noticed it tried to connect to port 22... which is the default one, not the one of my server :roll: After putting the correct port I get the next error, more explicit (about the key), I should be able to get it working, I'll investigate that later. [ edit: it works fine now! ]
You are welcome. I'm glad you have sorted it out.
Tigerente
Post by Tigerente »
Any Idea how to use the plugin as a "Hot Path"?
-edit- I found it. :)
sftpplug:\Sitename\
