How enable thumbnail preview of PDF files?
sparrowsav
Post by sparrowsav »
Hi, I'm new at using Salamander, I've been tinkering around with the options it has to offer but I haven't been able to find a definitive way to enable documents (i.e., PDFs) to have an image preview on the thumbnail. I see that it is generally mentioned as being a capability of the software, but I can't find out how to actually do that.
I'm using Windows 10 in case thats needed.
Thanks for any guidance.
Re: How enable thumbnail preview of PDF files?
You can't currently do that, only if you write a plugin.
There was a plugin called Explorer Thumbnails Plugin. There is no source code available and the plugin developer zarevak did not continue the development.
Next time also try to search the forum first before asking a duplicate question - this has been already discussed here pdf thumbnails?.
