Save display style (brief, detailled ...) per folder
McLion
Post by McLion »
Hi
Is there way to have Salamander store i.e. Thumbnails display mode for pane(s) for certain folders only?
Cheers
McL
Re: Save display style (brief, detailled ...) per folder
No, so far I know there isn't. But also I dont think its necessary as it takes only one keyboard shortcut press to change the view.
see ALT+<number>
McLion
Post by McLion »
OK. I know most of the keyboard shortcuts. That's what I like about Salamander and I work with it mostly with the shortcuts.
It was just an idea that would add to the usability for some folders.
No problem, the fact is that he development of Salamander is halted indefinitely. The Altap guys got a new job a while ago, which takes all their DEV time. There won't be any development in the near future. Only major bugfixes.
McLion
Post by McLion »
.. yup, unfortunately ... such a great tool ..
