RPM Plugin not working
wepe
Post by wepe »
When trying to open an RPM file, there is a popup that tells that there is an error in the TAR-plugin. The message tells that the archive format is not recognized or supported.
Re: RPM Plugin not working
The only way is for the developers, there are no active once at the moment, to update the plugin.
