Global file/folder masks
Rht74
Post by Rht74 »
Hi
plz. incorporate global file-masking with names so you can use named masks to:
select multiple files types
colorize
search
run plugins
ect.
Thank you for a Good program!!!
Re: Global file/folder masks
a) What do you mean by global file masking?
b) there isnt going to be a further developement of Salamander anytime soon. Its been halted ar infinitum
Rht74
Post by Rht74 »
a) that any named group of filemasks can be used in the entire program to select or do anything, if i name a group of filemasks /document/ *.doc,*.wri.*.xls
i can search, colorize, run plugins ect. with the group /document/
b) sorry to hear that, had high hopes :-)
Ok, now I understand what you mean.
I am afraid that this is not going to happen any time soon. Sorry.
