Window does not open
MacAlb
Post by MacAlb »
Hi
i want to use hashcheck ( http://code.kliu.org/hashcheck/ )
Salamander 2.54 doesnt open the window to save the checksumfile when i use
the rightclick to a file.
I can chose "Create Checksum File" but then nothing happens.
(Totalcommander or freecommander make this as wanted. Starting
explorer.exe works find too)
Best regards
MacAlb
Re: Window does not open
This must be a 32/64-bit issue.
Salamander is a 32-bit app.
You must be running a 64-bit OS.
When you installed HashCheck, it installs either a 32 or 64 bit version of itself depending upon your OS.
And obviously it chose the 64-bit version in your case.
Both the 32 & 64-bit dlls are in the download.
They can be extracted with 7-zip.
Don't know if (something as simple as) replacing the existing 64-bit dll with the 32-bit dll would then cause it to work in Salamander?
Or would it then be broken everywhere (or everywhere else)?
 Directory of C:\TMP\hashc\x86-32
07/04/2009  01:54 AM            92,672 HashCheck.dll
 Directory of C:\TMP\hashc\x86-64
07/04/2009  01:54 AM            99,328 HashCheck.dll
I can reproduce this problem on Windows XP (32b) with AS 2.54. Thank you for reporting this problem, we will look into it.
