Change Attributes, unset readonly on Windows 7 64 bits
Change Attributes, unset read only on Windows 7 64 bits not working
I have Altap Salamander 2.54 on a PC with Windows 7 64 bits.
Hitting Ctrl-F2 to change a file from read-only to not read only does not work.
The attributes of the file before hitting Ctrl-F2 : RA
I hit Ctrl-F2, uncheck the read-only box.
Then when I close the attributes dialog box the file is still displayed with the attributes RA.
It is not a display bug, the file is still read only in Windows Explorer and in Cygwin.
Right clicking on the file to open the attributes option works, but I guess this dialog box is implemented by Windows, not by Salamander.
Making a writable file readonly with the Ctrl-F2 dialog works.
By the way it would be good if Altap would make a 64 bits build of Salamander.
Regards.
Regards.
Re: Change Attributes, unset readonly on Windows 7 64 bits
Unsetting R attribute works for me (Win7x64). What file are you operating on?
Same behavior here on my Win7x64 - unchecking Read-only doesn't work.antoine wrote:Change Attributes, unset read only on Windows 7 64 bits not working
Are you really unchecking the checkbox? It's a tristate box - set, don't change and unset (in this order).
Well, now it worksEther wrote:Are you really unchecking the checkbox? It's a tristate box - set, don't change and unset (in this order).
I've long seen that, but never realized/understood the "don't change" setting.It's a tristate box - set, don't change and unset (in this order).
Could you explain that a bit further.
Where would this typically come into play?
Suppose it would be where multiple files are selected, with varying attributes, & you wanted to affect a change only to some of the attributes.
Is 'don't change' really used that often?
Thinking (at least for me), preferred order would be set/unset (toggle) & lastly don't change.
Typically I drop to a prompt & type: ATTRIB -A /S.
Or many times I'll pull a "hidden" file from %TMP% & in order to remove the Hidden attribute (from within the Change Attributes dialog), need to hit Ctrl+H twice to actually unset it.
I would expect the behavior similar to Windows properties dialog, i.e. set the tristate to the attribute only if I select files with different value of the attribute.
Yes, that's the scenario.therube wrote:Where would this typically come into play?
When I think about it, it really doesn't make sense to allow the third state if you know the attribute is the same for all the files. But then the behavior would be inconsistent. Sometimes you'd have to click twice, sometimes once. I'd hate to have to think about how many clicks I need to do.MartinS wrote:I would expect the behavior similar to Windows properties dialog, i.e. set the tristate to the attribute only if I select files with different value of the attribute.
Yes, this is the reason...Ether wrote:I think about it, it really doesn't make sense to allow the third state if you know the attribute is the same for all the files. But then the behavior would be inconsistent. Sometimes you'd have to click twice, sometimes once. I'd hate to have to think about how many clicks I need to do.
For me, exactly this is what I currently find annoying: to check I have to click once, to uncheck I have to click twice. At least with a single file (or multiple files with equal attributes).Sometimes you'd have to click twice, sometimes once. I'd hate to have to think about how many clicks I need to do.
I don't quite understand the argument.
For attributes that are equal for all files, the don't change mode is useless and confusing. If that can be left out, the number of clicking will be more consistent. Current situation:
from to clicks
checked clear 2
clear checked 1
both clear 1
both checked 2
from to clicks
checked clear 1
clear checked 1
both clear 1
both checked 2
I can't agree with the checked > clear and clear > checked part. One click is only when you don't allow the both state, so it's still inconsistent if you use the tristate when it's needed. An alternative where your numbers would hold is that the both state can be set as default, but once changed to something else, it cannot be restored (only by closing the dialog and opening it again).mdruiter wrote:Better:Code: Select all
from to clicks checked clear 1 clear checked 1 both clear 1 both checked 2
For attributes that are equal for all files the tristate has no use. Worse: it is confusing! And (only) those attributes start in the (un)checked state anyway.One click is only when you don't allow the both state, so it's still inconsistent if you use the tristate when it's needed.
Therefore I suggest to include the don't change option only for attributes that are not equal for all files.
Maybe I'm missing you're point.
So if the A attribute is not equal for all files and the R attribute is, your A checkbox would behave differently than your R checkbox?mdruiter wrote:Therefore I suggest to include the don't change option only for attributes that are not equal for all files.
Exactly. As the don't change mode is useless and confusing for R.if the A attribute is not equal for all files and the R attribute is, your A checkbox would behave differently than your R checkbox?
That would be just like Windows does it, by te way.
If I were to change attributes of various files often, I'd hate this. An IMHO probable scenario:mdruiter wrote:Exactly. As the don't change mode is useless and confusing for R.if the A attribute is not equal for all files and the R attribute is, your A checkbox would behave differently than your R checkbox?
OK, so let's remove the R from all these files - it was in the third state, OK - click once - unchecked - yes! - but wait! - I didn't mean to remove the R attribute, I was thinking of A - so, R is checked and let's revert it - click - not enough, let's click again - OK, that's it - now, A is checked - I can double click it to uncheck it - what? checked again? - oh, wait, this one works differently, I have to click only once...
