Regex bug in internal viewer
mdruiter
Post by mdruiter »
I encountered a weird bug when searching for a regular expression in the internal viewer.
Try this:
- save this (or enclosed) file:
1 XXXXXX_CCCCCCCCCC
3 XXXXXX_AAAAAAAA
4 XXXXXX_BBBBBBBB
6 XXXXXX_AAAAAAAA XXXXXX_BBBBBBBB
- open it in the internal viewer
- search for this regular expression (forward, not whole word, case insensitive):
XXXXXX_AAAAAAAA|XXXXXX_BBBBBBBB|XXXXXX_CCCCCCCCCC|YYY_DDDDDDDDDD|YYY_EEEEEEEEEE|YYY_FFFFFFFF|YYY_GGGGGGGGGGG|YYY_HHHHHHHH|ZZZ_YYY_IIIIIIII|YYY_JJJJJJJJJ|YYY_KKKKKKKKK|YYY_LLLL|YYY_MMMMMMMMMM
- press F3 to find the next occurrence
After finding line 1, line 4 is found and highlighted, and then the last part of line 6 (both XXXXXX_BBBBBBBB. :?
I would expect to find XXXXXX_AAAAAAAA as well, in lines 3 and 6! :(
If I press Shift+F3 to search backwards, all occurrences are found.
regexbug.txt
Test file
(311 Bytes) Downloaded 415 times
Re: Regex bug in internal viewer
I can confirm this, though I have no idea what causes this. The bug seems to manifest only when all the alternatives contain an underscore and only when the expression is of certain length or longer.
Thanks for finding this bug! I have fixed it and we will it in next beta version. I expect it is not critical.
It was in operators precedence (+ is above &):
original: #define NEXT(p) (((*((p)+1)&0377)<<8) + *((p)+2)&0377)
fixed: #define NEXT(p) (((*((p)+1)&0377)<<8) + (*((p)+2)&0377))
(original NEXT cannot never give result over 255 which was neccessary it this case)
mdruiter
Regex bug in Find too
Post by mdruiter »
I found a very similar thing in Find Files and Directories.
Try this:
1 N_PL
- in that directory, press Ctrl+F
- search for files containing this regular expression (not whole word, case insensitive):
XXXXXXXX|XXXX|XXXXXX|N_PL|XXXXXXX|XXXXXXX|XXXXX|XXXXXXXXXXXXX|XXXXXXXXXXXXX|XXXXXX|XXXXXXXXXXX|XXXXXXXXXXXXX|XXXXXXX|XXXXXXX|XXXXXXX|XXXXXXX|XXXXXXXXX|XXXXXXXX|XXXXXXXX|XXXXXXXX
The file will not be found! :(
If I remove the last character of the regular expression, the file is found as expected.
I think not finding files is a little more critical than not finding parts in a file.
findthis.txt
Example file
(208 Bytes) Downloaded 457 times
Thanks for report! Find uses the same library, so it is fixed too. I have found this library also in Renamer and FTP Search plugins, but this bug has already been fixed there (unfortunately this fix has not been propagated back to Salamander).
mdruiter
Post by mdruiter »
Great! I'll wait! :-)
