[Solved] Shortcut for hot path not work
Yanjin
Post by Yanjin »
I set several hot paths, but the hot key 'Ctrl + 1, 2, ... not work, the panel didn't change to corresponding path.
Software version is 4.0(x64)
OS version is win10 x64 1903
Update:
The shortcut works after I reinstalled it.
Re: Shortcut for hot path not work
Looks to be working as expected on my end.
Win7 & Win10 (1803, I think it was), Salamander 3.08 & 4.0.
Anything "odd" with the path you're using?
If you copy the path's value (to clipboard), can you Shift+Ins to switch to it in one of the Salamander panels?
Please show us a sample of your hot path configuration.
Yanjin
Post by Yanjin »
@therube and @SelfMan, thanks for your replying.
Today I reinstalled it, and now the shortcut works.
Re: [Resolved] Shortcut for hot path not work
You are welcome :D
