Can't change the command shell
luc0x61
Post by luc0x61 »
Looks like I don't find where to find the command shell to launch, as I'd like to change cmd.exe with TCC... I mean, this is possible, is it?
Re: Can't change the command shell
Its a system wide setting at:
hklm\system\currentcontrolset\control\session manager\environment
comspec
defualt value is set to:
%SystemRoot%\system32\cmd.exe
change it with the path to your favorite CMD replacement.
luc0x61
Post by luc0x61 »
SelfMan wrote: 04 Jul 2019, 22:13 Its a system wide setting at:
Now this is a bit of a radical intervention :D
I'd have been happy for it to be limited to this application...
How does it work in Total Commander? Could you please link some documentation?
