History od directories
Posted: 22 Feb 2006, 11:33
Hi there -> a small request here.
If there could be an option to sort the history list of last used directories alphabetically.
And an even better solution would be something like this:
for the upper 5 items there would be 'last used directories' as currently -> no order or as used,
then there would be a separator line and
then alphabetically used directories that you have used some time ago.
Why all this?
Simply searching to find just the right directory you want to return to is very hard -> especially if you have 20+ directories listed.
So finding the right directory would be very quick.
This feature would definitely be a nice too see in Salamander and can't wait the next version of Salamander.
Peace
Waldemar
Why all this?
Peace
Waldemar
