Waldemar wrote:This is not the problem of left and right panels -> the directory listings for left and for right should stay separate as they are now.
> ...the directory listings ...should
stay separate as
they are now
This list are
not separate but merged from left and right history.
Did i understand you wrong?
BTW
even better would be an search able history list:
1. click on the little down arrow
2. type a few first letter from the path or folder you want to change in
2b and SS should go in the history list to the first entry with this letter found
2c scroll with the arrow key to the history entry you want
hmm, like in the panels if you search for an folder.
BTW
and what's about more entrys in this history list..., ..scroll able like
the start menu with dozent of entrys.
Normal you would see only the standard amount of 30-40 entrys
but if you scroll down you will see more.
Would be sometimes nifty.
And what's about an kind of "black list" for the history...
... i mean exclude drive Z: and the cd-rom drive from store in the history
... or exclude my private sub sub folder
... or an "white list"
exclude sub-folder from an deep of 4 sub-folder, than merge all
this sub sub sub fiolder entrys to one history entry only.
C:\DocASet\User1\MyDocs\Tools\Network\Tool1
C:\DocASet\User1\MyDocs\Tools\Network\Tool2
C:\DocASet\User1\MyDocs\Tools\Network\Tool3\Doc\v1.2
and show f.ex. only in the history
