SFTP: File Rename Problem
crystalidea
Post by crystalidea »
When I have 2 files on SFTP:
program.exe
program.exe_
and try renaming the second one to 'program.exe' i get the question:
File 'program.exe' already exists. Overwrite?
The answer is YES, get the error:
General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Request code: 18
Martin Prikryl
Re: SFTP Rename Problem
Post by Martin Prikryl »
Your server most likely does not support renaming file to a name of already existing file.
For details about this unfortunate error message, please see here:
http://winscp.net/eng/docs/message_error_code_4
Martin Prikryl
https://winscp.net/
crystalidea
Other SFTP clients rename the file without a problem (on the same server).
Anyway, what the problem to delete, then rename huh?
crystalidea
any feedback from developers?
Martin Prikryl
XPiS wrote:Other SFTP clients rename the file without a problem (on the same server).
It can be improved. I'm adding it to a TODO list.
Martin Prikryl
https://winscp.net/
crystalidea
Re: SFTP: File Rename Problem
Thank you Martin, great.
crystalidea
1.6.5 - not fixed
crystalidea
any news?
Martin Prikryl
Sorry, no progress yet. To be honest, this is really not a very demanded feature.
Martin Prikryl
https://winscp.net/
crystalidea
It's not like 1k lines of code I believe. I have a problem of using this for years.
