Clipboard issue with EditPad Pro
dpokluda
Post by dpokluda »
I have the following issue with Altap Salamander working together with EditPad Pro. When I copy a text to the clipboard in EditPad Pro and exit EditPad Pro, the clipboard text disappears. I tried to communicate with the EditPad Pro author but he claims he can't reproduce the issue even though I can reproduce it easily (with free alternative to EditPad Pro - EditPad Lite):
  • Run Altap Salamander
    Navigate to Option > Configuration...
    Go to Viewers and Editors > Editors
    Set editor for *.* to be C:\Program Files (x86)\EditPadLite\EditPadLite.exe
  • Now navigate to a text file, for example C:\Windows\system.ini (or any other file - it doesn't matter what file you select)
    Press F4 to edit the file in EditPad Lite
    Select some text and hit Ctrl+C
    Exit EditPad Lite (EditPad Lite is now closed)
  • Move to the command line (Ctrl+Tab I believe) and Press Ctrl+V to paste the text
    --> NOTHING HAPPENS, CLIPBOARD IS EMPTY! <--
I have Windows 7 Ultimate 64-bit. I am not saying that the problem is with Altap Salamander. It might be a combination of things between Salamander and EditPad Pro. I am willing to help you troubleshoot/debug the issue but I don't know how. Please let me know if I can do something to help you with this issue.
BTW: If after I copy the text to the clipboard I paste it to another application then the issue doesn't repro.
Thanks,
David.
Re: Clipboard issue with EditPad Pro
Hi David, I can reproduce it. The EditPadLite.exe can be started just from panel (as EXE). Interesting problem, seems to be related to Salamander. Thank you for info!
dpokluda
Post by dpokluda »
Oh, thank you for that info. I was working with Jan (who has written EditPad Pro) for a long time and he couldn't figure out the issue. I was about to write a service that would monitor the clipboard (retrieve its content) to minimize occurance of this issue.
dpokluda
Post by dpokluda »
Anything new regarding this? (just curious)
David.
