Move files with selective text
docfxit
Post by docfxit »
Does anyone know if there is a way to move a text file from one folder to another only if it has "ToReturnCode>31" in the text file?
Thank you,
Docfxit
Re: Move files with selective text
Are you trying to move files in a complicated directory structure or just in one or two directories? In the latter case, you could just find the files using Find, Cut (Ctrl+X) them and Paste (Ctrl+V) them where you want.
docfxit
Post by docfxit »
That is really super. It worked really great. You just saved me hours of work.
I had no idea that could be done. What a great feature.
Thank you very much.
I often wondered how smart the find window was. I have wanted the capability many many times to select a file in the find window and have it take me to the Salamander double pane window. Is there a way to do that?
Just above the list of found files, is a button ... Focus.
Oh, & you may find some of the Shortcut Keys of interest too.
Like Alt+Insert & Shift+Insert ...
docfxit
Post by docfxit »
therube wrote:Just above the list of found files, is a button ... Focus.
Thank you very much. I've been looking for Focus for years.
That's great.
Docfxit
