The Salamander is still not portable, but you can do it easily with an Autoit script:
#NoTrayIcon
RunWait("regedit.exe /E " & @ScriptDir & "\temp.reg HKEY_CURRENT_USER\Software\Altap")
RunWait("regedit.exe /S " & @ScriptDir & "\config_.reg")
RunWait(@ScriptDir & "/salamand.exe", "", @SW_MAXIMIZE)
RegDelete("HKEY_CURRENT_USER\Software\Altap")
If FileExists(@ScriptDir & "\temp.reg") Then
RunWait("regedit.exe /S " & @ScriptDir & "\temp.reg")
FileDelete(@ScriptDir & "\temp.reg")
EndIf
Compile (Autoit) that script (Salrun.au3) and run it in the root directory of Salamander on USB-stick. It works well and fast also if on the host PC is another Salamander installed. (Script and EXE is attached)
How to make Salamander "portable" for an USB-stick ?
- Salrun.zip
- script and compiled EXE
- (188.11 KiB) Downloaded 737 times
Re: How to make Salamander "portable" for an USB-stick ?
Will be possible to describe whole install procedure with more details pls?
(something like: Make AS directory on USB stick. Copy Salrun + as254.exe there..)
I do not understand your question. do the following:
1. download salrun.zip
2. copy the "salrun.exe" into an installed Salamander-directory
3. export under Salamander the configuration (config_.reg)
4. copy the complete directory to you USB-stick
5. run "Salrun.exe instead of salamand.exe
that is all ...
J. Agam
that is all ...
J. Agam
Thank - now it's easy to follow - and fully function on my memory card!
