TEMP environment variable
Pasha T.
Post by Pasha T. »
After changing TEMP environment variable and restarting computer Salamander use old (before changing) TEMP folder.
Please, fix this.
Re: TEMP environment variable
Are you sure that %TMP% is set to a valid location?
Do other programs correctly use the new %TMP% location?
Windows has two env vars to store the location of the temporary directory - TEMP and TMP. Did you change both of them? Also, where and how did you change it? The usual way (Control Panel > System > Advanced > Environment Variables) present two sets of env vars - the ones you want to change are labeled User Variables.
Note: the Encrypt & Decrypt plugin has a separate temporary directory setting.
Pasha T.
Post by Pasha T. »
My mistake.
No problem in new ver of Salamander.
And what was the mistake?
