Crash of AS 2.53
Eric
Crash of AS 2.53
Post by Eric »
When I try to open a file via an application defined in the User Menu (Video, Text File), AS crashes.
This happens when the fullpath of file is too long.
Thanks
Eric
AS2.53
Win2008R2
Re: Crash of AS 2.53
Is Bug Report window displayed?
Eric
Post by Eric »
No, only the Windows Crash Dialog.
Problem signature:
Problem Event Name: BEX
Application Name: salamand.exe
Application Version: 2.5.3.63
Application Timestamp: 4c249b78
Fault Module Name: StackHash_d542
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0000766b
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7600.2.0.0.272.7
Locale ID: 2055
Additional Information 1: d542
Additional Information 2: d542a25112d07207ec573ba61e246a6e
Additional Information 3: 24c5
Additional Information 4: 24c52d933f3acf10a631f9d5babd56f2
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Thank you Eric. Could you please show us exactly the User Menu command, parameters, paths, file names, so we can try to reproduce it?
Eric
Post by Eric »
Here is a screen dump.
It doesn't really matter which values, I tried to change the arguments or inital directory. I used another command (notepad++).
Same crash.
Thanks
Thank you. It looks pretty normal. So the problem is in long path where you are starting the user menu command?
How long is this path?
Eric
Post by Eric »
About 280 chars. When I try to rename the file, I get a warning because "of too long name".
Eric, I can reproduce this problem. We will fix it, thank you for the report.
Problem is fixed. Fix will be released with next version of Salamander.
