Compare folders - Files one hour difference
docfxit
Post by docfxit »
I am trying to compare folders with files that most of the time have one hour difference.
One set of files is on the hard drive NTFS
The other set of files is on a thumb drive FAT32.
I understand why there is a difference.
I have put a check mark in: Options, Configuration,Confirmations, Compare Directories, ignored differences of exactly 1 or 2 hours.
Re: Compare folders - Files one hour difference
What version of Salamander are you running?
>> #docfxit: I'm running XP Pro Ver. 2.53 beta 2
How much are the times off?
Just above the 1 or 2 hour difference, there is also a setting for _xx_ (up to 3600) seconds.
With that set, will that adjust for the times?
Other then time, the files are actually the same?
Post a screenshot of the panels showing time differences.
docfxit
Post by docfxit »
therube wrote:What version of Salamander are you running?
I'm running ver. 2.53 beta 2
I don't see the setting for seconds.
You're in the wrong spot.
That's for a Confirmation.
You want, General.
(I think I did the same thing early on. Yep, similar, http://forum.altap.cz/viewtopic.php?f=2 ... l&start=15.)
docfxit
Post by docfxit »
therube wrote: You want, General.
That's supper. Thank you for catching that. I had no idea.
It works great now.
Thanks,
Docfxit
