W7x64-7Zip Right Context Menu Not showing in Salamander
vld
Post by vld »
Trying to zip up a file with 7Zip and if I right click on the files within Salamander, the context menu does not appear. It does appear however if I am within Explorer. Works fine on XP. Haven't been able to test to see if it is a x64 issue or a W7 issue with Salamander. Anyone notice this?
Re: W7x64-7Zip Right Context Menu Not showing in Salamander
You're using the 64-bit version of 7-Zip?
I believe, that at present, the answer is that you'll need to use the 32-bit for the right-click context menu to appear.
See, What next? Vote please: x64 version or UAC support.
With some other programs, you are able to install both the 32 & 64-bit versions. Don't know if that applies to 7-zip?
