Altap Salamander 2.53 Beta 2
Krzysztof Bytnerowicz
Post by Krzysztof Bytnerowicz »
I downloaded and tried it yesterday. I found that the drive pop-up menu lost 'Network' selection. I was able to map the drive using path name without problems but network scanning is missing.
Re: Altap Salamander 2.53 Beta 2
Please check menu Plugins > Plugins Manager. Choose the Network plugin and look at option "Show Network item in Change Drive menu and Drive Info". Is this option set?
Jan,
None of my plugins, in beta 2 and 3 show as loaded, but, I noticed that Beta3 did not have 'show network..' ticked on, and beta 2 had. I ticked the selection and it shows on the menu now. Perhaps some quirk in upgrade from beta 2 to beta 3.
Thanks a lot,
Krzysztof
Krzysztof Bytnerowicz wrote:None of my plugins, in beta 2 and 3 show as loaded
It's normal behavior, plugins are "unloaded" until Salamander needs them.
