File Comparator FYI
Posted: 06 May 2010, 03:48
File Comparator - FYI
Just to point out that the Autodetect Files Type may not be the optimal choice - depending upon circumstances.
Like if you were comparing MP3s.
An MP3 would be Autodetected as a binary file.
WMP has a habit of playing with MP3 tags.
So what you may have archived away could end up being different from the same file once it has been played in WMP.
If you were to use Comparator using its' defaults, with the MP3s detected as binary, most likely, in this situation, you would not be presented with particularly relevant results. (Most likely the files would appear to be substantially different.)
However, having some idea that the change may be tag related, manually selecting Text File Type in Comparator would very clearly point out that the change was in fact tag related, with the actual changes to the file in fact being very minor.
