File Comparator FYI
File Comparator FYI
File Comparator - FYI
Just to point out that the Autodetect Files Type may not be the optimal choice - depending upon circumstances.
Like if you were comparing MP3s.
An MP3 would be Autodetected as a binary file.
WMP has a habit of playing with MP3 tags.
So what you may have archived away could end up being different from the same file once it has been played in WMP.
If you were to use Comparator using its' defaults, with the MP3s detected as binary, most likely, in this situation, you would not be presented with particularly relevant results. (Most likely the files would appear to be substantially different.)
However, having some idea that the change may be tag related, manually selecting Text File Type in Comparator would very clearly point out that the change was in fact tag related, with the actual changes to the file in fact being very minor.
Re: File Comparator FYI
therube wrote:An MP3 would be Autodetected as a binary file.
That's of course correct.
mdruiter
Post by mdruiter »
Maybe therube means that it would be great if the File Comparator would only consider the changed part(s) during its file type detection. But that's a Catch-22 situation. :mrgreen:
Correct.
In a way, I guess you can say.
But that's my point. It cannot "know" the right method all the time. So, someone else may need to help it (File Comparator) out a bit ;-).
In my particular scenario, binary happens to be the correct choice based on file contents, but the comparison algorithm used for binary happens to be "incorrect" for the particular situation encountered. (The binary comparison algorithm is entirely correct, only when used here, it does not present pertinent data, thereby making it "incorrect", where a textual comparison will present data in a pertinent manner.)
mdruiter
Post by mdruiter »
Yes.
But 'correct' is not a boolean. :-) The algorithm detecting file type is also 'correct'. But it's only making a guess. Probably according to a simple rule, such as "if it contains something weird, assume binary". My idea would be to improve this rule a bit, by considering Esc as "not so weird" (see http://forum.altap.cz/viewtopic.php?f=2&t=3945).
Of course no rule can ever be perfect. If it were, the choice between "automatic, text, binary" would not be necessary. So I guess we completely agree!
