Bug Report:
If I compare 2 files "config_.reg"
- produced by Altap Salamander 2.53 beta 1 (using "Export Configuration...") -
with the "File Comparator" Plugin of Altap Salamander 2.52 or 2.53 beta 1
- "Options" "Default Compare Options" set to "File Type" "Autodetect" or "Text" -
then the lines from 1 to 332 are not shown.
File Comparator starts config_.reg at line 333
Re: File Comparator starts config_.reg at line 333
Unfortunately it is not clear to me what you are comparing with what (i.e. what the second file is). Can you provide us the files you are comparing?TÜV wrote:Bug Report:
Just use "Export Configuration..." to produce "config_.reg", rename it, change someting in Altap Salamander, then use "Export Configuration.." again and compare the text inside the renamed config_.reg with the text inside the new config_.reg
- File Comparator Text Start-Error.png (51.01 KiB) Viewed 9680 times
Sorry, my fault: "Show Only Differences" was selected. Please delete this topic.
