AS 2.53b1 - error on folder deletion
Posted: 14 Mar 2010, 23:11
by rollhigh
Hi Altap,
I am running windows 7 ultimate 64bit RTM with Altap Salamander 2.53 B1on NTFS f/s.
I am seeing the following error when I attempt to delete certain folders, none of the files are opened in the background so there should be no locks on the files/folder.
Please see below...
Many Thanks
Re: AS 2.53b1 - error on folder deletion
Posted: 14 Mar 2010, 23:16
Try to find out what application has locked your file. You can use Manison's Offender plugin.
Posted: 14 Mar 2010, 23:20
Also please try to delete such file with Windows Explorer (use Shift+F3 to open Explorer for current directory).
Posted: 14 Mar 2010, 23:23
The problem can be related to Media Player: http://social.answers.microsoft.com/For ... 82fe6ea900
Posted: 19 Mar 2010, 04:46
by jcgriff2
Was that the actual error message - no editng of screenshot?
