AS 2.53b1 - error on folder deletion
rollhigh
Post by rollhigh »
Hi Altap,
I am running windows 7 ultimate 64bit RTM with Altap Salamander 2.53 B1on NTFS f/s.
I am seeing the following error when I attempt to delete certain folders, none of the files are opened in the background so there should be no locks on the files/folder.
Please see below...
Many Thanks
Re: AS 2.53b1 - error on folder deletion
Try to find out what application has locked your file. You can use Manison's Offender plugin.
Also please try to delete such file with Windows Explorer (use Shift+F3 to open Explorer for current directory).
The problem can be related to Media Player: http://social.answers.microsoft.com/For ... 82fe6ea900
jcgriff2
Post by jcgriff2 »
Was that the actual error message - no editng of screenshot?
J. C. Griffith
Microsoft MVP
Windows Expert - IT Pro
