AS 2.53beta1: Automation plugin: help file
Posted: 08 Mar 2010, 10:08
by th.
When the Automation plugin was introduced as a standalone plugin, the script path for the current user was C:\Users\<username>\AppData\Roaming\Altap\Altap Salamander\Automation\scripts (Vista/Windows7). Obviously that has changed since it became a part of AS, it is now C:\Users\<username>\AppData\Roaming\Altap Salamander\Automation\scripts (changeable in the configuration). However, the help file has not been updated with respect to that change.
I think it should also be mentioned there that it is possible to use subfolders in the script directories to create submenus in the script menu.
Re: AS 2.53beta1: Automation plugin: help file
Posted: 08 Mar 2010, 10:57
Fixed, thank you.
Posted: 08 Mar 2010, 13:39
by th.
I've just noticed that the script menu is now updated immediately after changes in the script directories. This has to be changed in the help file as well.
Most of the version 1.1 new objects are only mentioned on the "What's new" page but not described. Makes it hard to use them :(
Posted: 08 Mar 2010, 14:26
Fixed.
Please use direct access from Help > Plugins > Automation > Reference. New objects and methods are documented there. Just links from the "what's new" page were broken.
Feel free to ask if you have any questions.
Posted: 08 Mar 2010, 15:19
by th.
I'm sorry, I can't find the Form object as well as Button, Checkbox and so on.
Posted: 08 Mar 2010, 15:25
I'm sorry, my fault. Please use attached version of the Automation help. Replace it at C:\Program Files (x86)\Altap Salamander (beta)\help\english\automation.chm.
automation.7z
Automation help update for AS 2.53b1. Released 03/08/2010.
(35.14 KiB) Downloaded 947 times
Posted: 08 Mar 2010, 15:54
by th.
Thanks.
