When the Automation plugin was introduced as a standalone plugin, the script path for the current user was C:\Users\<username>\AppData\Roaming\Altap\Altap Salamander\Automation\scripts (Vista/Windows7). Obviously that has changed since it became a part of AS, it is now C:\Users\<username>\AppData\Roaming\Altap Salamander\Automation\scripts (changeable in the configuration). However, the help file has not been updated with respect to that change.
I think it should also be mentioned there that it is possible to use subfolders in the script directories to create submenus in the script menu.
AS 2.53beta1: Automation plugin: help file
Re: AS 2.53beta1: Automation plugin: help file
Fixed, thank you.
I've just noticed that the script menu is now updated immediately after changes in the script directories. This has to be changed in the help file as well.
Most of the version 1.1 new objects are only mentioned on the "What's new" page but not described. Makes it hard to use them
Fixed.
Please use direct access from Help > Plugins > Automation > Reference. New objects and methods are documented there. Just links from the "what's new" page were broken.
Feel free to ask if you have any questions.
I'm sorry, I can't find the Form object as well as Button, Checkbox and so on.
- AutomationPluginHelp.png (84.89 KiB) Viewed 17782 times
I'm sorry, my fault. Please use attached version of the Automation help. Replace it at C:\Program Files (x86)\Altap Salamander (beta)\help\english\automation.chm.
