Context menu problem with 7-Zip in Salamander
Nazarene
Post by Nazarene »
Hi there
I am having a problem with my context menu when I right click on a zip/7z file. I have had this for the last three versions (and possibly longer?) - 2.51, 2.52 and now the last two EAP versions.
When I right click on a zip/7z file in Salamander it doesn't show the 7-Zip context item in the context menu - everything else shows as normal...
When I do the same in Explorer it shows the context menu correctly, with the 7-Zip options there.
Hopefully the image will help me to explain the problem:
SS Problem.jpg (150.18 KiB) Viewed 12328 times
I am on Windows 7 Ultimate 64-Bit and I have uninstalled and reinstalled Salamander, uninstalled and reinstalled 7-Zip, with and without Admin priviledges... so I am a bit stuck now...
Any ideas/suggestions will be tried out.
Thanks
10 Year Servant Salamander/Altap Salamander user
Riaan Prinsloo
A .jpg is worth a thousand .txts
Re: Context menu problem with 7-Zip in Salamander
Hi, it's known x86/x64 conflict, please see http://forum.altap.cz/viewtopic.php?f=2&t=3749 and vote at http://forum.altap.cz/viewtopic.php?f=4&t=3597.
Thank you.
ino
Post by ino »
Nazarene wrote: I am on Windows 7 Ultimate 64-Bit and I have uninstalled and reinstalled Salamander, uninstalled and reinstalled 7-Zip, with and without Admin priviledges... so I am a bit stuck now...
I am running on WXP 32 and context menu looks the same in AS and in Explorer. May be problem of 64bits
Nazarene wrote: A .jpg is worth a thousand .txts
Thats true, just do not use JPG but PNG - see this post: http://forum.altap.cz/viewtopic.php?f=2 ... 696#p15696
Until there is a 64-bit version of Altap Salamander, install both versions of 7-zip: 32-bit AND 64-bit. The 64-bit version will be used in native 64-bit Explorer and other 64-bit applications and 32-bit version will be used by 32-bit applications including Altap Salamander or Microsoft Office :)
Installing both 7-Zip versions at the same time is completelly supported method and it will allow Salamander to use 7-Zip shell extension :)
Nazarene
Post by Nazarene »
Zarevak - thank you - that worked perfectly!! :D
