The Early Access Program (EAP) gives you the opportunity to download and install the latest development release to test new features and bug fixes even before beta version release. This Preview Build version could contain serious bugs and shoud not be used in production environments. Use it only for testing. Moreover this version is time limited, it expires approx. after half year, expiration date is in main window title.
Note: If you are looking for latest release version, please download it here.
Download EAP version: Altap Salamander 2.53 beta 1 (Preview Build 44)
Download SDK for EAP version: SDK for Altap Salamander 2.53 beta 1 (Preview Build 44)[/hide]
If you are interested in new Preview Build versions and you are using Altap Salamander 2.52 (or later), select Check for preview build versions check box in menu Options / Plugin Configuration / Check Version.
Altap Salamander 2.53 beta 1 (PB 44) Change List: - Archives containing two or more files with the same name: View command worked only with the first opened file (View command on all other files with the same name opened wrongly always only the first opened file). - Last Command name in Plugins menu newly contains also plugin's name. It solves conflicts with the same command names used in more plugins, e.g. Disconnect (FTP and WinSCP) or Test Archive (ZIP and 7-Zip). http://forum.altap.cz/viewtopic.php?t=3163 + SDK version of Salamander (Preview Builds and SDK builds): SDK version contains trace messages. Added Autostart Altap Trace Server and Log Trace Messages to File items to window menu (click on icon in upper left corner of main window). On the first start of SDK version of Salamander, it displays question if you want to start Altap Trace Server automatically. - Added trace messages for wrong plugin language modules, now it should be clear why SLG module cannot be loaded. - Configuration dialog box: GUI font is used in page caption instead of system font. - Find dialog: wrong font was displayed in Focus toolbar button after change of Windows Appearance. See http://forum.altap.cz/viewtopic.php?f=6&t=3622 + Find: width of the Size column updated for current (2010) file sizes. Size up to 1TB will displayed without clipping. http://forum.altap.cz/viewtopic.php?f=16&t=3655 - Find: Sort by Path doesn't honour directories / files grouping as other Sort by does. http://forum.altap.cz/viewtopic.php?f=7&t=3676 - Find: Date column width was calculated from current date, so 31.12.2009 was truncated on 1.1.2010. Now is calculated for 30.12.2000. Output of GetDateFormat(LOCALE_USER_DEFAULT, DATE_SHORTDATE...) is checked for alpha charactes. When alpha char is found, longest possible month and day is searched and used for column width. Time column is tested for morning and afternoon (AM/PM) time now. - Reduced number of DST confirmations in Compare Directories. They are shown only if changing of "Compare Directories: ignore time differences of exactly one or two hours" may lead to different results of Compare Directories command. http://forum.altap.cz/viewtopic.php?f=24&t=3672 - Help: removed unused keyboard shortcuts, see http://forum.altap.cz/viewtopic.php?f=2&t=2141 + Copy/Move operations to archives and plugin file systems: warning "Options will be ignored" could be suppressed. Option could be also set in Options > Configuration > Confirmations > Show message. http://forum.altap.cz/viewtopic.php?f=24&t=3678 - Extended context menu (hold Shift key when context menu is shown) is supported in Find window, Change Drive Menu, etc. http://forum.altap.cz/viewtopic.php?t=3748 - Plugins Manager > Keyboard: removed hot keys from buttons, dialog box is not beeping for Alt+key or Alt+Shift+key combinations. - Main windows is no longer beeping for Alt+Shift+key combinations owned by some plugin command. NEW PLUGIN: Automation With the Automation plugin you can automate common tasks using scripts written in any language supported by the Windows Script Host. Windows comes with JScript and VBScript engines preinstalled, however 3rd party scripting engines are available for languages such as Perl, PHP, Python, Ruby and others. Automation plugin comes with comprehensive documentation (see Help > Contents > Plugins > Automation) and sample scripts (see plugins\automation\scripts). We are just launching Automation Script Contest for 3 free licenses of Altap Salamander. WinSCP: + See http://winscp.net/eng/docs/salamander_history#1.6.3 - Bug fix: http://forum.altap.cz/viewtopic.php?f=14&t=3601 ZIP: + Added custom column "Packed". + Supports unpacking to alternative filename when opening file for viewer, solves http://forum.altap.cz/viewtopic.php?f=2&t=2842 + Illegal chars in file and folder names inside archive replaced with underscore, solves http://forum.altap.cz/viewtopic.php?f=6&t=3662 + File and folder names in UTF8 inside archive are detected and converted to local encoding. - Proper handling of files of the same name in the same (sub)directory. 7-ZIP: + Updated to 9.10 Beta. + All read and write errors no longer cause hard failure but have a dialog with Retry & Abort buttons. - Mark encrypted files with Encrypted attribute, partially solves http://forum.altap.cz/viewtopic.php?f=24&t=3686. + Custom column "Packed Size" renamed to "Packed". + Custom columns are now empty for folders, they used to be "DIR". UnRAR: + Added custom column "Packed". + Added support for multi-part archives with naming .001, .002, 003, etc. Solves 2n part of http://forum.altap.cz/viewtopic.php?f=7&t=1634 - "Select First Volume" dialog is no longer shown When the fist part of a multi-part archive is called XXX.part01.rar and the file exists. Solves http://forum.altap.cz/viewtopic.php?f=7&t=1634 - The correct file is extracted when filenames inside an archive are not unique. PictView: - Wrong area was sometimes erased between images in animated sequences, namely some GIF's. Solves http://forum.altap.cz/viewtopic.php?f=6&t=3667 Multimedia Viewer: + UTF8 support in WMA. - "Copy All" didn't work for UTF8 items. UnISO: - Do not read beyond image size when scanning for track file systems (solves http://forum.altap.cz/viewtopic.php?t=3773). Registry Editor: + Shift+F3 opens regedit.exe with current registry key displayed. http://forum.altap.cz/viewtopic.php?f=7&t=3741 File Comparator: - The '&' character was not displayed properly in panels titles (file names). http://forum.altap.cz/viewtopic.php?f=6&t=3739 Portable Executable Viewer: - Fixed displaying import tables of some Vista32 drivers, see http://forum.altap.cz/viewtopic.php?f=6&t=3651. UnFAT: + Plugin has been added to SDK (published).
