Extend salamander commands in find dialog?
Posted: 15 Feb 2010, 16:42
OK, after my silly init post I'll try again
I use find command a lot, but from it dialog I can't access salamander commands to process find list, sometimes is handy batch rename the list other times manipulate selection or do something with filenames (case/encoding) and so on
Right now I've made user command with ECHO to findlist.txt in my temp folder, then I work the list additionally
I know that salamander is thinked tip top, and maybe this shouldn't be considered as feature request, but I'd like to hear some thoughts or usage examples with find dialog
Thanks
[edit] OK, I found tons of posts with requests for extending find dialog commands which makes my post useless. I should have searched first
Thanks
