Extend salamander commands in find dialog?
otrov
Post by otrov »
OK, after my silly init post I'll try again :)
I use find command a lot, but from it dialog I can't access salamander commands to process find list, sometimes is handy batch rename the list other times manipulate selection or do something with filenames (case/encoding) and so on
Right now I've made user command with ECHO to findlist.txt in my temp folder, then I work the list additionally
I know that salamander is thinked tip top, and maybe this shouldn't be considered as feature request, but I'd like to hear some thoughts or usage examples with find dialog
Thanks
[edit] OK, I found tons of posts with requests for extending find dialog commands which makes my post useless. I should have searched first
otrov
Re: Extend salamander commands in find dialog?
Post by otrov »
Thinking again, making "*.*" search would equal as missing command that displays folder items together with it sub folder items (possible in Dos Navigator and it clones)
Maybe if we could save the list than have option to load it in salamander panel, things like that can be sorted out
Also it seems that it's impossible to search inside archives
otrov
Post by otrov »
yea, virtual panel would be another fine approach it seems
