Using Salamander's FTP plugin (FTP Client 1.23 in AS 2.51), the connection fails. Using FileZilla or Windows Vista Console ftp.exe, the connection succeeds.
Here are logs
Connecting to "169.254.2.1" (169.254.2.1) on port 21.
Log UID is 3, time is 24.01.2010 - 20:46:51.
220 Welcome to Mobile File Service
USER admin
331 User name Ok, need password.
--------------------------- FTP Error --------------------------- Connection to server has failed. Most likely, it is not FTP server nor FTP proxy server. Server reply: --------------------------- [OK] ---------------------------
Status: Verbinde mit 169.254.2.1:21...
Status: Verbindung hergestellt, warte auf Willkommensnachricht...
Antwort: 220 Welcome to Mobile File Service
Befehl: USER admin
Antwort: 331 User name Ok, need password.
Befehl: PASS *****
Antwort: 230 Logged in.
Befehl: SYST
Antwort: 215 UNIX Type: L8
Befehl: FEAT
Antwort: 202 Command not implemented.
Status: Verbunden
Something seems to be strange about the server though, since I cannot logon to it using telnet client. Nevertheless, Filezilla and ftp.exe can. Using telnet I get the welcome message, but no reply on the USER command. Furthermore, if a tarry for just a little while the server disconnects.
