Using Briefcase
Using Briefcase
Is it possible to use Windows Briefcase with Salamander to synchronise files? Or is there an even better way to keep directory structures between several Computers in sync with Salamander, using network connections and a thumb drive as transport media? (OS is Win XP/Vista/7 at the time beeing 32-bit throughout.)
Re: Using Briefcase
I don't think it's possible to reasonably integrate any external synchronizing application with Salamander using User Menu or similar methods. On the other hand, a plugin could do that job.
