file selection status after operation
Posted: 31 Dec 2009, 18:18
Is there any way in Salamander 2.5 to retain the selection state of files when they are moved from one directory to another? I am working with drawing files which have revisions as part of the filename. When I move updated drawings into a directory, if the files continued to show selected coloring, I can easily remove the older versions since they will be sorted by name.
