file selection status after operation
sierkh
Post by sierkh »
Is there any way in Salamander 2.5 to retain the selection state of files when they are moved from one directory to another? I am working with drawing files which have revisions as part of the filename. When I move updated drawings into a directory, if the files continued to show selected coloring, I can easily remove the older versions since they will be sorted by name.
Re: file selection status after operation
Of course its there. Ctrl+Shift+F5 and Ctrl+Shift+F6
Check the manual at: "Using Altap Salamander" > "Advanced Working with Files and Directories" > "Saving and Loading Selection"
