Is it possible? If not, I'd like to make a feature request for this.
For example, I've created a preset that outputs the files list as a markdown bullet list with links to the files:
- [`$(FileName)`](./$(FileName))$(CRLF)I'm not sure how Altap Salamander saves the list of recently used presets for this Command. After saving the configuration and launching a new instance of AS, the last used Line was available in the new instance dropdown, but not on other previously open instances. So it seems like AS is saving these as part of the configuration.
So I've peeked at the registry and found it was saved at:
HKEY_CURRENT_USER\Software\Altap\Altap Salamander 3.08\Configuration\File List HistoryIf I wanted to create some custom presets and share them with others, how should I go about it? If was to export the "File List History" key it would contain all sort of used commands, and they seem to be arbitrarily numbered. My guess is that it can't be done without using some custom code to check the number of entries present in a users "File List History" and generate the presets number accordingly (this also applies to other history-based settings in Altap Salamander).
What would be an easy way to add lots of presets to the "File List History" without overwriting anything?
I think it would be nice to have another menu beside the Line dropdown history and the button on the right for picking variables: a menu to access presets that can be managed (eg: import/export presets) and organized by categories, and stored in a plaintext settings file of sorts and shared with others.
