View active topics not working?
Since the board update, is View active topics not working? Or have there been no active topics to view?
Appears not to be working, cause it should have found this post at the least, yet it did not.
(View new posts does work <but I don't typically use that>.)
Re: View active topics not working?
Fixed, thank you for this information. More about this problem: http://www.phpbb.com/community/viewtopi ... &t=1859245
Thanks.
(Heh. Not the first time that a fix for something that wasn't working ended up then "breaking" what worked in the past. A feature that was supposed to be a feature but was one by virtue of a bug.)
