I have saved "Wait until all other Copy/Move operations are finished" as default option for copying/moving. Now when I copy some files per FTP the following information pops up every time:
"You have specified some special options (see Options button in Copy/Move dialog). These options are not supported when copying/moving to plugin filesystems. Options will be ignored."
This may be true and okay for accidently setting options or similar, but you should either be able to let AS ignore this from now on or don't display this at all if the conflicting option is set as default. Getting this warning everytime is kinda annoying.
PB38: Not supported options
Forum rules
Re: PB38: Not supported options
From next EAP version of Salamander it will be possible to suppress this message.
