Order of files in windows
ETB
Post by ETB »
Somehow the order (asending/decending) in alphabetical order has
switched from ascending to decending. How to I reverse the order?
The order in the right side stayed asending.
Thank you.
Re: Order of files in windows
Just click on the 'Name' column header again.
Note: the Header Line is not visible in all view modes.
You can set the sorting mode in menu Left (Right) and the Sort By submenu.
For more information about sorting please look at Altap Salamander Help.
ETB wrote:Somehow the order (asending/decending) in alphabetical order has
Thank you.
Or just hit Ctrl+F3 which you probably hit. Check help file for keyboard shortcuts/hotkeys.
