Used space: 18.446.744.009.683.054.592 bytes
mdruiter
Post by mdruiter »
Somehow (?), Drive Information shows a lot of used space on one of my network drives:
Screen shot
Screen shot
Free space.png (15.79 KiB) Viewed 11443 times
Almost 16 EB used! :shock:
The drive's Properties in Explorer seems to calculate space in another way: the used space is the sum of the actual file sizes, and the free space is the difference between quota (2 GB for me) and used space:
Used space: 280.309.760 bytes (267 MB)
Free space: 1.867.173.888 bytes (1,73 GB)
Capacity: 2.147.483.648 bytes (2,00 GB)
Windows Explorer also says "23 items (Disk free space: 1,73 GB)" in the Status Bar.
Re: Used space: 18.446.744.009.683.054.592 bytes
Hi, could you please tell us more about your Windows version and about the network drive? Is it another Windows machine? What version?
Salamander 2.52?
Edit: we need to do something with the dialog box layout...
The big number is unsigned int64 representation of -64GB (2 - 66 = -64). I'll fix this problem in the first preview build of version 2.53.
mdruiter
Post by mdruiter »
Jan Rysavy wrote:Hi, could you please tell us more about your Windows version and about the network drive? Is it another Windows machine? What version? Salamander 2.52?
My OS is Windows Vista Business x64. The drive is a mapped NFS share on a Windows Server 2003 machine. I use Salamander 2.52.
I think the problem is the quota.
I do not understand why Salamander thinks 66GB is free (I think this really is the space on the 'disk'), but Windows Explorer thinks only 1,73GB (maybe the quota left?). I have only 84MB in use of the 2GB quota so I would say 1,92GB... :?
Hope this helps.
Fixed. It will be available in beta 3 which will be release this month.
