Go to upper directory by dbl click
yam
Post by yam »
I mostly work with mouse.
It would be nice to have a feature double clicking on empty space to go to upper directory. It's inconvenient to goto upper directory if it contains many files/folders as the shortcut "..." button doesn't always remain visible(i mean scrolling makes it out of view)
Re: Go to upper directory by dbl click
yam wrote:double clicking on empty space would go to upper directory. ... it contains many files/folders as the shortcut "..." button doesn't always remain visible(i mean scrolling makes it out of view)
Well, in that case I think there is no "empty" space, but the entire panel is covered by files/folders...
Jan Patera wrote:Well, in that case I think there is no "empty" space, but the entire panel is covered by files/folders...
I think there's some space on the right, if the filenames are short enough.
ino
Post by ino »
yam wrote:"..." button doesn't always remain visible(i mean scrolling makes it out of view)
do you know about the Directory Line click feature?
There is no need to use double click. One click is enough to go to any of upper directory. And Directory line is always visible (if not disabled by user settings) regardless of number of folders or files you have in current view just above each panel .
How to?
For example there is a path to current directory set to D:\WINNT\Cursors on the screenshot. If you want to go directly to the root directory - click on the D:, if you want to go just to upper directory - just click on the WINNT. Or even more. If you want to go to different directory - click on the last directory name (in this case on Cursors) then you will get Change Directory dialog boxe to go whenever you want.
Screenshot from the help page of Directory Line
It might help you to navigate using mouse although I prefer Backspace key ;-)
th.
Post by th. »
Not to forget the "Parent Directory" button in the top toolbar or in the middle toolbar.
Also in the Panel toolbar:
yam
Post by yam »
yes i do know breadcrumb and the toolbar buttons. Now if i m suppose at bottom of list then i have to move mouse(no i'm not lazy)...but still it would save time.
yam wrote:i have to move mouse(no i'm not lazy)...but still it would save time.
;-) That's exactly the reason (speed) why many people prefer the keyboard over the mouse. Or they have one hand on the mouse and one on the keyboard a use the one which is more appropriate (faster) at the given moment.
yam
Post by yam »
Don't use keyboard for browsing. And many people does so.
You should try Quick Search. It really does make difference.
Ultimately, I'd rephrase this feature request as:
when you implement mouse gestures, don't forget to add <up> for Go to Parent Directory
I think that would do the trick and also tells us when we can expect this feature.
